HondaCivicForum.com
-   -   Head Gasket (https://www.hondacivicforum.com/forum/engine-internal-11/head-gasket-1206/)
Importman04 Sep 25, 2004 02:45 PM
Head Gasket
I have to replace the head gasket on my CRX should I go ahead and take the head to the machine shop or should i just put the gasket on? I know this is a stupid question but i figured i would just ask.
sacicons Sep 25, 2004 04:34 PM
RE: Head Gasket
yeah, you never know if there is a little warpage in the head and the new gasket might just blow, get it milled a little, even go a little extra and it will raise the compression. take off about .020-.030 inches, then you will want an adjustable cam gear because it throws off your cam timing. you will love the extra power. just be sure to run premium. you could see as much as 15-20 hp at the wheels with that.
Deleted User Sep 25, 2004 09:07 PM
[Deleted]
[Deleted by Admins]
Importman04 Sep 25, 2004 11:13 PM
RE: Head Gasket
what does an adjustable cam gear cost? I am just making ths motor las until i can get LS motor and tranny from my friend then its engine swap time :D
sacicons Sep 26, 2004 10:05 AM
RE: Head Gasket
i think around 75 bucks, but honestly, after you do that, you may not want a heavy ls motor. ive seen sohc vtecs with that done that were faster than SIs.
Importman04 Sep 26, 2004 12:55 PM
RE: Head Gasket
the motor i have in my car right now is a non vtec motor
sacicons Sep 26, 2004 05:14 PM
RE: Head Gasket
yeah i know, but you may still change your mind;) and the vtec one i saw could hang with SIs with a few bolt ons, while thats about all he had, it was mostly stock otherwise.
Importman04 Sep 26, 2004 05:29 PM
RE: Head Gasket
then what kind of motor would be a good motor to put in it for a daily driver/ racer?
sacicons Sep 26, 2004 07:34 PM
RE: Head Gasket
drag race or what?
Importman04 Sep 27, 2004 07:33 PM
RE: Head Gasket
just to race somebody on the road if they try to mess wiht me, thats is the reason y i am thinking of going wiht the LS motor because of the torque that it has
