Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 08-06-2005, 04:34 PM
seanperia seanperia is offline
My Garage
Send a message via AIM to seanperia
Default 94 Civic DX wont start when hot outside...
hey guys i need help in diagnosing this problem. my car is a 94 Civic DX all stock...it does not want to start when its hot outside. it cranks but it wont run. i replaced the spark plugs, wires, cap, rotor, air filter, PCV valve. i thought it was just the filter because it was so clogged but it still didnt start. im looking into replacing the fuel filter and/or fuel pump as that maybe the cause of the problem and also trying to check out the ignition coil if its bad. but i need some of the honda guys inputs because the fuel pumps on hondas dont really give up from what i heard.
__________________
Just me and my stock honda civic dx
Sponsored Links
Old 08-06-2005, 05:36 PM
civicraider civicraider is offline
My Garage
Default RE: 94 Civic DX wont start when hot outside...
2 WORDS--> Vapor Lock!
__________________
98 civic EX
5spd 2000 front end conversion, JDM fogs and Side Markers
Turbo k in process
HID COnversion in Progress
1992 Prelude Si
White w/black interior was a DD now Dead -- Part out
Old 08-06-2005, 06:05 PM
My Garage
so how do i solve that if that is the problem? so i replace the fuel filter right? thanks.
__________________
Old 08-07-2005, 09:22 AM
My Garage
not sure on the cure but you could look on the internet and it would give you common ways to combat vapor lock. cause what happens is your gas evaporates cause its getting so hot and literally your car tries to run on Fumes and cant!
__________________
98 civic EX
Turbo k in process
1992 Prelude Si
Old 08-07-2005, 10:46 AM
maachan513 maachan513 is offline
My Garage
When you turn the ignition key on, the fuel pump should come on momentarily to purge the system. This shold take care of vapor lock issue. Upon engine start, the pump come on and keep running till turned off.
I would listen for the pump sound as I turn the key on slowly. If there is no sound, then I would locate the pump and hot wire the pump to see if it turns. If the pump is ok then the system is at fault........
This is how I troubleshooted on my 924S a few years back. I think Hondas have similar system. If not, sorry!
Maachan513
Old 08-07-2005, 11:12 AM
sacicons sacicons is offline
My Garage
i highly doubt its vapor lock. modern cars dont have many (or any) problems with that. i dont have my haynes manual on me, ill get it today and see if you still need help on this.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 08-08-2005, 05:35 PM
My Garage
replaced filter yesterday and i think its getting fuel. i drove it to work this morning but by the time that i was ready to leave at like 4 it didnt want to start again. so anyone?
__________________
Old 08-08-2005, 06:51 PM
LEVIII LEVIII is offline
My Garage
If you have a friend or anyone with a civic swap ignitors.
I really think that may be it.
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 08-08-2005, 10:30 PM
My Garage
Quote:
ORIGINAL: LEVIII
ignitors? as in coils?
__________________
Old 08-08-2005, 11:08 PM
My Garage
Singular, you only have one
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
