Go Back   HondaCivicForum.com > Your Ride > ECU Tuning & Fuel Management
Reply
Old 10-07-2004, 02:55 PM
dmsteele92831 dmsteele92831 is offline
My Garage
Default Mini me ecu
What ecu should I use for a mini me swap of a ex d16y8, should I go with the stock ex p2p ecu or convert to OBD1 then get a different ecu? Keep in mind I am going to mill the head, port and polish it and eventually end up putting in a S/C.
Sponsored Links
Old 10-07-2004, 07:13 PM
Importman04 Importman04 is offline
My Garage
Default RE: Mini me ecu
What kind of S/C are you going with?
__________________
When you pull up to a Domestic you lean out the window a say "You wanna VTEC"
Old 10-07-2004, 08:07 PM
My Garage
Jackson S/C
Old 10-07-2004, 08:56 PM
sacicons sacicons is offline
My Garage
dont mill the head if you are planning to go FI. it will raise compression and you will have detonation issues with the SC. and personally, id go obd1. its a lot easier to tune.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 10-07-2004, 10:50 PM
My Garage
What is an OBD1?
__________________
Old 10-08-2004, 11:45 AM
My Garage
OBD1 is the electronic name for 92-95 civics (someone correct if I'm wrong) 96-00 civics are OBD2. You can buy a harness off Ebay from $50.00 to $150.00 that will convert your OBD2 civic (96-00) to OBD1. The reason it is preferable to do this is because you can run a P28 ECU (or any other that you want) and they are easier to tune and chip than the OBD2 ECU. I'm going to convert to OBD1 and get the p28 ecu and have it chipped. By chipped they raise the fuel/air curve, adjust the vtec (sometimes) and it supposedly adds 10-20 Hp depending on what you have done ie. headers, intake, exhaust, cam etc. One guy off ebay will even ask you all the mods you have then chip your ecu accordingly
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
