cleaning under the hood
Login | |
RE: cleaning under the hood - 8/16/2005 8:27:06 PM
ngoti 8tor
Just use some engine degreaser (no-name works ok for this), and cover any sensitive parts (like air filter) with plastic if it's sticking out (like a SRI or CAI). Spray your warm engine with the degreaser, then after 15-20 minutes, hose it off (car wash sprayer works well here).
_____________________________
ngoti8tor "I see", said the blind man pissing into the wind, "It's all coming back to me now". quote:
ORIGINAL: 2000 LoW reD Si haha ngo your like the forums...sex guru.
RE: cleaning under the hood - 8/16/2005 8:36:02 PM
mill$civic
i would use a engine degreeser and a powerfull hose then use rags and armeral to touch it up, make sure you cover up everything that shouldent get wet such as your alternator,fuse box, sparkplug...ect, or what you could do, is just get out some rags, armeral, and a brush and some degreeser and put the degreeser on and then brush, then wipe off and use some elbow greese if you dont want to use a hose, ether way works good...i clean without the hose
Member since Feb 2005
