I'm torn.
I can't decide between the Edelbrock kit and the Turbonetics kit. The Turbonetics kit runs 8 psi and puts out around 200hp while the Edelbrock kit only puts out around 170hp. I can get the Turbonetics kit for cheaper than the Edelbrock kit, but I really can't decide. Here are some specs:
Turbonetics: -T3/T4 Hybrid Ceramic Ball Bearing Turbocharger -Spearco Intercooler System -Powder-Coated Intercooler Piping -Silicone Hose / T-Bolt Clamps -Exhaust Manifold - high carbon cast-steel with ceramic coating -Fuel / Timing Controller (electronic fuel / timing management system) -Fuel Injectors -'Evolution' Wastegate Assembly -'Raptor' By Pass / Blow Off Valve Assembly -Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge -Intake System with Air Filter -All necessary Hardware, Hoses, and Fittings -Free Case of Turbonetics TS-1 Synthetic Motor Oil It's got 2 extra fuel injectors with a fuel injector controller and a MSD boost timing master. Comes with external wastegate. Edelbrock: -Garrett T28 ball bearing Turbo preassembled with exhaust manifold and elbow, including coolant and oil lines -Performer X manifold preassembled with secondary fuel rail and four additional injectors -State-of-the-art electronics to control boosted fuel and timing -Preassembled Russell fuel and oil lines with adapters -Large Spearco intercooler with TIG welded cast aluminum end tanks -Tial blow-off valve -Edelbrock boost gauge by Auto Meter with A-pillar mount pod -Ceramic coated Turbo piping and high flow air filter -All gaskets, adapters and instructions -O-ring sealed compressor inlet/outlet pipe flanges Has 4 extra injectors instead of 2, has internal wastegate, comes with boost gauge, 50 state legal. Basically it comes down to which is better: The T28 or the T3/T4. I'm sort of leaning towards Turbonetics because I can get it for $2900 and I get more power with it. |
RE: I'm torn.
From what I read, they both look like they come with comparable stuff, so IMO, I would go for the Turbonetics kit and save some cash. Turbonetics is a fairly well known brand now, and I find you pay a lot more just for the Edelbrock name.
RE: I'm torn.
If I were you, Id go with the turbonetics. Im looking into getting a turbo, and Ive heard great things about them. Plus, youll save some cash, and get 30 extra horeses, but thats just me.
RE: I'm torn.
turbonetics bro. Hands down.
RE: I'm torn.
Ok, I'm going with the turbonetics kit, and I'm going to use the extra money I save to buy a turbo timer, possibly a boost gauge, and possibly the greddy emanage.
RE: I'm torn.
[sm=dontgetit.gif]Unless i read it wrong how come this was a hard choice? the turbonetics cost less and 30HP more?anyways seems like you got your answer so [sm=happybounce.gif]
RE: I'm torn.
Well lots of other people I have talked to said the Edelbrock kit was awesome, and I'm not too worried about how much power I'll be getting right now. I'll be adjusting that a little further down the road...;)
RE: I'm torn.
i too don't see the part that makes you 2nd guess
RE: I'm torn.
ORIGINAL: XCM828 Ok, I'm going with the turbonetics kit, and I'm going to use the extra money I save to buy a turbo timer, possibly a boost gauge, and possibly the greddy emanage. Also, the last time I looked the Turbonetics kit was about the same price as the Edelbrock. |
RE: I'm torn.
Last time I checked the turbokits.com was having a huge sale on turbonetics...:D
| All times are GMT -8. The time now is 05:25 PM. |
