Brake noise FIXED
Login | |
RE: Brake noise - 8/24/2005 9:41:26 PM
mxs
Ok, it's still doing it and I still don't know where the noise is coming from. Allow me to demonstrate as I brake from, say, 25 mph: bump bump bump bump... thwap.. thwap.......thwap... thwap................ thwap...... thwap.........................scrape Does that help? It's now been 200 or so miles since I had the rotors turned. Add to that a (hopefully unrelated) ricer-fart-can type sound that started yesterday while accelerating (sounds like it might be coming from the cat?) and my car now sounds like it is falling apart. THIS IS NOT GOOD. Does anyone have any ideas what it might be and maybe what I could check out myself? Thanks in advance Sincerely, Your pal Marnie
_____________________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3. DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
RE: Brake noise - 8/24/2005 9:55:09 PM
ngoti 8tor
quote:
ORIGINAL: mxs bump bump bump bump... thwap.. thwap.......thwap... thwap................ thwap...... thwap.........................scrape Hi Marnie! Great sound effects there, but I still can't tell you anything from that. It could literally be almost anything. Or even a combination of things.
ngoti8tor "I see", said the blind man pissing into the wind, "It's all coming back to me now". quote:
ORIGINAL: 2000 LoW reD Si haha ngo your like the forums...sex guru.
RE: Brake noise - 8/24/2005 11:06:04 PM
mxs
Yeah, that's the next best thing to a sound clip. I guess...
RE: Brake noise - 8/25/2005 1:41:00 AM
maddawg
take it to a shop usaully it take them a couple of tries and by this time they've fixed 2 other things too free of charge b/c when you pickl up the car they usaully say it's fixed
HELP ME POST A SIG
RE: Brake noise - 8/25/2005 9:45:14 AM
mxs
quote:
ORIGINAL: mxs ... Add to that a (hopefully unrelated) ricer-fart-can type sound that started yesterday while accelerating (sounds like it might be coming from the cat?) and my car now sounds like it is falling apart. edit, the exhaust is now in 2 pieces
RE: Brake noise - 8/25/2005 11:32:52 AM
Roto
Joined: 11/15/2004 From: Centralia, PA Status: offline
Inspect you exhaust...something probably rotted off..
PM me if you would like custom made vinyl stickers, magnetics, poster, or banners.
RE: Brake noise - 8/26/2005 5:47:29 PM
mxs
BUMP because the brakes are still making noise... (exhaust problem fixed though)
RE: Brake noise - 8/26/2005 6:52:30 PM
ngoti 8tor
Are the brakes still makin the same noise, or is it different. If it's a high-pitched noise (like a squeal), it could be that the pads have glazed over, in which you have to remove them and rough them up with sand paper or something.
RE: Brake noise - 8/27/2005 10:50:31 AM
mxs
Well no it's not really a squeal, but you might be on to something. I'm thinking maybe some of the pad material tansferred to the rotor, maybe from coming to a stop too quickly (and holding the brakes) when the rotors were "new" (even though I tried not to do that). Maybe I'll hit the pads and rotors with some sandpaper. Won't be until later though, because my roommate is using the driveway today. (it's only fair, I've been hogging it on saturdays for 2 months now )
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
