Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 08-26-2005, 04:57 PM
civicdriver609 civicdriver609 is offline
My Garage
Default Watching in dash dvd player without the parking brake pulled up
HEY GUYS I HAVE A QUESTION.. IS THERE A WAY I CAN WATCH A DVD WITHOUT HAVING THE PARKING BRAKEPULLED UP ON MY IN DASH DVD PLAYER?? CUZ ONE OF THE WIRES FROM THE SYSTEM IS CONNECTED TO THE NEGATIVE PARKING BRAKE WIRE.. I TRIED TO DISCONECTED THE WIRE SO I CAN WATCH IT WHILE DRIVING BUT IT WONT WORK PROPERLY UNLESS ITS CONNTECTED TO THE WIRE.. IS THERE A WAY TO GET AROUND THIS??
Sponsored Links
Old 08-26-2005, 05:02 PM
My Garage
Default RE: Watching in dash dvd player without the parking brake pulled up
YEA I KNO IMMA NEWBIE BUT HELP A BROTHA OUT ~LOL~
Old 08-26-2005, 08:55 PM
Chimera02EX Chimera02EX is offline
My Garage
Send a message via AIM to Chimera02EX
if its just connected to the negative parking brake wire you could just try grounding it to a screw. The only reason it works when it's connected to the parking brake is because the negative wire on the p-brake is "open" when not pulled up and "closed" when pulled up... so if you just ground the dvd player to a screw or a negative wire that is always "closed" it should work all the time. I hope this helps.
Old 08-27-2005, 10:38 AM
j_fukin_t j_fukin_t is offline
My Garage
all depends on what unit you have, the new pioneers shut off at 10mph, it can deff be a pain in the ass
Old 08-27-2005, 02:08 PM
D16z6's Avatar
D16z6 D16z6 is offline
My Garage
that dangerous watching tv and driving at the sametime.
__________________
A
Old 08-27-2005, 02:20 PM
My Garage
Quote:
ORIGINAL: j_fukin_t
well i just bout a jensen.. Well hookin the wire up to a screw will work??? any screw???
Old 08-27-2005, 02:21 PM
My Garage
Quote:
ORIGINAL: HondaCivica
yes i kno it is but its for the passengers
Old 08-27-2005, 03:13 PM
My Garage
Like I said before it SHOULD and yes any screw will do, but it'd be better if it was screwed into metal not plastic. I don't know much about the dvd players themselves but as far as electrical principles go I'm pretty good. Try hooking it up to a screw under the center console those are usually metal on metal. It's the grounding wire so as long as it isnt hooked up to anything with power flowing through it (+ or normally red) you could hook it up to any black ground wire also. Try it, the worst that could happen (supposing it isn't hooked up to a power source) is the dvd player won't turn on.
Old 08-27-2005, 03:47 PM
Pete Pete is offline
My Garage
Send a message via Yahoo to Pete
just ground it......it worked with my pioneer.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 08-27-2005, 06:20 PM
My Garage
just make sure you have a solid ground and use washers to keep it tight so you don't ever have to tear apart the counsel again, i'll have my video system in next week, so we want pics
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
