Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 08-29-2005, 12:19 PM
puckfan80 puckfan80 is offline
My Garage
Default Temp. gauge going up and down
I have a 95 civic DX and the temperature gauge on the interior gauge cluster keeps on going up and down at a rapid pace. I know that the temperature of a car probably could not flucuate that quickly, so I'm wondering what it could be? The car only has 75k on it.
Any help would be appreciated, thanks.
Sponsored Links
Old 08-29-2005, 01:21 PM
ngoti 8tor ngoti 8tor is offline
My Garage
Default RE: Temp. gauge going up and down
Uh oh! That usually means you have a head gasket leak or a cracked block. Check your oil and see if the color looks normal, or if it's kinda like hot chocolate.
Old 08-29-2005, 06:25 PM
shellebelle shellebelle is offline
My Garage
Sounds like my car! I have a '95 DX as well, and the head gasket started going last September, but I didn't do anything about it until May of this year (don't be stupid like me!). Get yourself into a reuputable shop and get a pressure test.
Total repair was about $625. A big chunk out of my wallet, but it's cheaper than a new engine down the line!
__________________
Quote:
ORIGINAL: Mossy
thats right, shelle keeps it real...
Old 08-29-2005, 07:41 PM
97CivicEX 97CivicEX is offline
My Garage
what do you mean by up and down at a rapid pace? If the needle is jumping around randomly it could be as simple as a grounding issue on the guage. If the needle is moving up and down in a smooth movement then yes it could be a head gasket, warped head or cracked head. get it checked out soon.
__________________
200,000 miles strong!!!
Black 4 door, WingsWest Racing Series Ground effects, DC 4-1 Headers, AEM CAI,
Edelbrock Performer X Turbo soon to come!
Old 08-29-2005, 08:31 PM
sacicons sacicons is offline
My Garage
or a thermostat thats stuck open.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 09-02-2005, 10:50 PM
Sharpshooter Sharpshooter is offline
My Garage
Mine was doing that about a month ago. These guys are great. Told me it was the head gasket and it was, my head was also warped .01". Get it machined, put a new head gasket on it, and your all fixed. Be sure to get it pressure checked also.
Old 09-03-2005, 01:19 AM
My Garage
So let us know what the problem actually is so that future HCFers know.
Old 07-27-2006, 12:03 PM
jim300 jim300 is offline
My Garage
I have recently seen the same problem. The gauge goes up and then back down slowly, but never gets real hot. I also noticed a loss of power when this happens. There's no smoke, and the engine runs great for about 30 minutes,no sputter, no misses and great acceleration..then seems to get sluggish. I relaced a stuck thermostat about 2 weeks ago, and there wasn't any problems til just a few days ago. Someone told me that I need to bleed the cooling system that I have air in it,..and there's a bleed port next to the thermostat,..? The oil looks ok,..no smoke, and no leaks,..is this a possible fix....jim
__________________
jimensminger
Old 07-27-2006, 04:16 PM
fglaustin fglaustin is offline
My Garage
i would think that it is the wiring (especially important to check it right there where it goes into the coolant temp sensor, or the sensor itself).
Old 08-04-2006, 05:02 AM
motoboy17us2007 motoboy17us2007 is offline
My Garage
Send a message via Yahoo to motoboy17us2007
Honda's have really small ports in the radiator too.... look for a green "fungus" on the top of it, if it's there change it!
__________________
95 EX VTEC 5spd
STOCK
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
