need help choosing amp
hey i was wondering wat kinda amp i would need to power 2 diamond auido cm312d4 subs. if anyone could help me determine wat specs for a amp i would need to look for ex. sensitivity, frequencies, ohms, wattz, channels. here are the specs for the subs
Sensitivity: 91 dB
RMS Power Range : 500 Watts
Impedance: 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 250 Hz
Diameter: 12 Inch
Radial vented steel basket
2.5" voice coil
Cmax Optimized Spider
Double Stacked Magnet
Power Range (W RMS):500
Impedance (ohms): Dual 4
Sensitivity (dB SPL): 91 (2.83-V input @ 1 meter)
Freq. Resp: 25Hz-250Hz(±3dB)
Diameter: 12"
Depth:5.4"
