Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 09-09-2005, 09:15 AM
90Civtegra's Avatar
90Civtegra 90Civtegra is online now
Send a message via AIM to 90Civtegra
Default Wiring up dual voice coil subs
I have 2 Audiobahn 12's that are dual voice coil, I have a dual 12" speaker box that has only one terminal for speaker hook up. How do I wire these subs up inside the box?
Counting on you DCA and Remmy!
__________________
-Kevin
Sponsored Links
Old 09-09-2005, 10:29 AM
LEVIII LEVIII is offline
Default RE: Wiring up dual voice coil subs
Depends on what amp you are running and how many ohms each voice coil is. Lemme know that and Ill tell you how to wire it up.
More then likely it will be series each sub and then parallel them to the amp.
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 09-09-2005, 10:32 AM
Remmy Remmy is offline
Administrator
Nice diagram. Thats pretty much how ya do it. I have more diagrams in the stickies if you wanna take a look at that.
__________________
Old 09-09-2005, 10:51 AM
90Civtegra's Avatar
Heres the spec off Audiobahns website on my amp
A5100T
5.1 surround amplifier
Class A/B MOSFET — High Current Hybrid Circuitry
PWM MOSFET Power Supplies
Double-Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB (+/- 1dB)
Frequency Response: 10Hz - 40KHz
Variable 18dB High-pass Crossovers: 30Hz - 500Hz
Variable 18dB Low-pass Crossovers: 30Hz - 120Hz
Center Channel Hi-Pass, Full or Bandpass for Mid-bass
Bass boost @ 45Hz: 0-18dB
6-Channel RCA Input Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
__________________
-Kevin
Old 09-09-2005, 01:02 PM
Administrator
What is the OHM specs... we dont need all of that.
__________________
Old 09-09-2005, 01:21 PM
90Civtegra's Avatar
thats all it tells me
__________________
-Kevin
Old 09-09-2005, 01:23 PM
Administrator
hmm.. we cant really tell unless we get the ohm specs. [&o]
__________________
Old 09-09-2005, 02:29 PM
amg6975 amg6975 is offline
With 4 voice coils total, assuming they're 4 ohm, you're stuck with either a 4 ohm setup (LEVIII's diagram) or a 1 ohm setup (look in sticky for diagram), which your amps says it'll handle.
I think that everyone's asking you for the specs of your subs, not amp to make sure they're 4 ohm voice coils.
__________________
Old 09-09-2005, 03:58 PM
90Civtegra's Avatar
I have the 12's so I guess they are 4ohm coils
__________________
-Kevin
Old 09-09-2005, 08:57 PM
Looks to me like the amp can handle 1 ohm to so hook all the posatives to the 1 posative and all the negs to the one neg and youll be pounding at 1 ohm 800 watts.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
