09-10-2005, 09:18 PM
My Garage
Trunk Release Lever
I tried to open my trunk by way of the lever inside the car, nothing happens. I turned the key each way not knowing which is lock or unlock, again it will not open.
The lever does not have slack and still fells taunt, like its releasing.
What do I need to do?
09-10-2005, 09:34 PM
My Garage
RE: Trunk Release Lever
check the lock. open it with your key there is a lever under there that u can disable the inside lever
__________________
19 inchs and 10 switchs........
09-10-2005, 10:53 PM
My Garage
So I need to pull the plastic cover up, correct?
09-11-2005, 02:26 AM
My Garage
i had a similar problem. turned out the cable was not attached in the trunk.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
09-11-2005, 10:26 AM
My Garage
or wait nevermind on my post my civic has a switch that u can hit and it disables the key on the trunk yea check to make sure the cable is attached
__________________
09-11-2005, 06:37 PM
My Garage
Make sure that the key clicks, It will move back and forth freely but it has to click and stay in the position to unlock it.
__________________
09-13-2005, 06:49 PM
My Garage
My key does turn either way, but there is no click. Help!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
