HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   1997 honda civic cx amp install problems (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/1997-honda-civic-cx-amp-install-problems-94952/)
blindwest49 Feb 22, 2013 09:40 PM
hey guys i just setup my sub and amp today i have everything set, i need to know a few things, i cant find a spot to ground because the ring terminal on my ground cable can only fit 8mm or 10mm screws, so idk what to do there, and i have no idea if my amps turning on, i got a Pioneer GM-5500T and theres no lights, so i got no clue if my remote wire is hooked up to a proper spot, i know about this blue cable with a white line i connected it to that and i got nothing, could that have to do with the ground or is it the wrong cable, help would be appreciated
mk378 Feb 23, 2013 04:56 PM
You have to ground the amp first. If you're installing it in the trunk there should be a usable ground bolt under the back seat. It grounds the fuel pump.
