98 civic Cd player wiring problem???
So I bought my 98 like 2 months ago and the cd player that was in it was a cheap knock off and never worked... I went in to replace it and noticed that whoever put the cd player in cut the harness and hardwired it in so i just used how that have it hooked up and nothing... Anyone have the wiring diagram for a 98? Any help would be awesome
thanks |
generally what i noticed in my hondas is the red wire and yellow wire are the power connect the 2 and the ground is black the blue is a remote/memory wire and you have to look at each speaker in the door to figure there color out pm me the colors and maybe i can tell you otherwise
This should help you: http://www.the12volt.com/installbay/...tail/1051.html
As always, make sure you test your power and ground wires with a meter. You can also use an AA battery to test the speaker connections, i.e. which ones pop when connected to the battery. |
Thanxs guys it was a major help!!!!
