Amp power wire
Hi, i got my 0awg wire for my amp running undernieth my car, its held up pretty good through the summer. My question is what u thought about leaving it through the winter, I dont know where else to hide it.
Any suggestions would be awsome!!! |
If you run it through split loom, it should be fine for years.
http://stores.amenomobile.com/images...20loom%202.jpg |
Never heard of an amp wire being run under the car before. I guess as long as the wiring does not have any rips or tears in the rubber/plastic/whatever lining, you should be fine. If you want added security, I would go with something like tigger posted. Hopefully, you are not lowered, or planning on lowering your car.
If you want to run it in the car, you have to pull out the seats, most of the panels, and pull up the carpet a little. Somewhat timing consuming, but that is what wiring is, time consuming if you want everything to look perfect. lol |
| All times are GMT -8. The time now is 07:36 AM. |
