amp power wire question
Old Feb 9, 2011 | 07:09 PM
bc_civic_guy's Avatar
Default amp power wire question
i have installed an amp and sub in my 04 civic and after i had all the wires run i noticed that i only had about 8 inches of power wire in the trunk to go to my amp. I was wondering if i could add a barrel connector and another chunk of wire so that i had more length or is this going to impeed on the current going to the amp
Old Feb 10, 2011 | 12:20 AM
TiggerDX's Avatar
What size wire are you running? Something you can do is install an inline fuse connector and extend from that. Or even a distribution block. This would work well... (at least it is what I use)
Stinger Fuse Block
Old Feb 10, 2011 | 05:08 AM
i'm using a 6 gauge power wire and i thought about adding another fuse but i wasn't sure if that was a good idea either since there is one under the hood close to the battery
Old Feb 10, 2011 | 10:41 AM
Sigracer10's Avatar
you should be fine doing either a distribution block or another fuse holder. Just Do Not us a barrel connector on that size wire. It will not transfer the current the same a way a distribution block would.
Old Feb 10, 2011 | 10:31 PM
TiggerDX's Avatar
If your amp isn't fused onboard, I would use a fuse block. If it is fused onboard, a distribution block would be fine (or a fuse block) Neither will hurt.
Old Feb 11, 2011 | 04:20 AM
Newfiedan's Avatar
You should have it fused as close to the battery as possible, adding a distribution block would work, and you can indeed extrend the wiring using a butt connector (or barrel as call it) but to get the current transfer you would need to solder and shrink tube it otherwise you will not get the current transfer. I do not recommend using the butt connector though, instead use the distribution block. As a side note I hope that when you ran the power wire that you ran it through a firewall grommet, otherwise you are setting yourself up for problems from the start.
civic_04
Feb 4, 2010 03:35 PM
xsdudztx
Aug 14, 2007 05:45 PM
xsdudztx
Aug 9, 2007 07:45 PM
fallenskater6541
Jun 14, 2007 06:28 PM
Cdude
Jun 25, 2006 10:51 PM
