Amp + Subs stopped Working
Old Apr 2, 2007 | 02:19 PM
RofoCivic's Avatar
Default Amp + Subs stopped Working
Hey guys, hope you can give me a hand with this one b/c its got me beat. Today I was getting rid of the huge and heavy box that holds my 2x10' subs. I got them out and so far so good. Then I went to go put them in again and started hooking stuff up and noticed that the my Amp wasn't powered up(when its powered there is a blue flashing color on it). Well i got everything hooked up and still things werent working so i changed the fuse for my 8 gauge wire. That still wasnt it...so now im confused. My amp is a Kenwood KAC-X520 , and 2 Rockford Fosgate subs. Any ideas what the problem might be?
Old Apr 2, 2007 | 02:25 PM
mill$civic's Avatar
Default RE: Amp + Subs stopped Working
My problem with this..the ground. Make sure its clean and a good contact.
If that doesnt work. Get a voltmeter and see where the power is stopping at or if there is power coming to the amp.
Old Apr 2, 2007 | 03:32 PM
thi3v3z's Avatar
a make sure the remote wire is plugged in, on both ends, make sure you have a good ground going to your amp, and finally check the fuses on ur amp, not just ur inlines.
Old Apr 2, 2007 | 04:35 PM
n8te81's Avatar
i was gonna say about the ground as well so check that....im still thinking that something still has to be unplugged cause you couldnt have blown something just by taking out your subs even if your subs touched metal or something like that.But then again if your amp isnt even coming on then its gotta be something fuse wise or another.Have you checked your amp fuses??
Old Apr 2, 2007 | 09:54 PM
RofoCivic's Avatar
Yea my ground is good and I didnt touch any of the amp wiring so nothing got unplugged from that. I havent checked my amp fuses but that is the only other thing it could be i guess. Where could i find a pair of amp fuses, they are 30A's think Pepboys or Advanced auto might have something like that or maybe even bestbuy, or might i have to order them online?
Old Apr 2, 2007 | 09:59 PM
n8te81's Avatar
any auto parts should have them for sure if that ends up being the problem...i would think it has to be....let us know what you find out.
Old Apr 2, 2007 | 10:02 PM
RofoCivic's Avatar
will do, gonna head there tomorrow i guess in the morn, thanks alot for the help guys
Old Apr 2, 2007 | 10:03 PM
thi3v3z's Avatar
just pull the fuses out and look at them, u can tell if they are blown
Old Apr 3, 2007 | 12:27 PM
RofoCivic's Avatar
yup both the fuses were blown thanks alot guys
Old Apr 3, 2007 | 02:29 PM
thi3v3z's Avatar
ok now heres the next question u should ask, why did they blow? when u pulled ur amp/subs out did u disconnect your battery first? thats a must!
Tigal
Mar 8, 2012 01:56 PM
dave_57204
Apr 6, 2008 05:38 PM
Bostonhoodhop
May 18, 2007 02:13 PM
farkus
Nov 24, 2005 08:46 PM
cfauvel
Sep 22, 2005 01:23 PM
