amp wiring
well the speaker wires are going to each of the 4 speakers. and although i'd love to have audio going down the center of the car, that sounds like a royal pain in the ***.
so far my plan is to run the power cord down the right hand side of the car (the side of the battery) and run the rca cable down the left. My only worry was when running the speaker wires from the amp i didn't know if they would be affected when they are near / if not parrallel to power on the right.
it is really in your best interst to keep em seperate, if you have well sheilded new cables, it might be ok, but u should rally have audio seperated from power, just cause you might run into interfearance
If youdo run wires on the same side of a vehicle...try not to run them parallel to each other..Cross them and get some space between them. The power wires can and will induce noise into the speaker wires. Obviously you can't avoid it (if you have more then two speakers) so do the best you can.
