HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   Car stereo has no power (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/car-stereo-has-no-power-66828/)
because Jun 21, 2008 09:02 AM
I have a 94 Civic. It had a crappy cd player in it when i got it so i wanted to put a different one in with an aux jack. I took the old on out and put the brand new one in...i even bought a new wiring harness. I've installed cd players in my other cars and never had a problem. This just doesnt get any power at all. Ive checked all the fuses, all the wires, everything i can think of. Also, when i disconnected my antenna wire from the back of the old cd player it broke and got stuck in the hole. Do i need this to get power to my radio? cause if not im not going to bother fixing it i never use the radio. Please help!! I just want my system back!
mk378 Jun 21, 2008 09:06 AM
RE: Car stereo has no power
Power for the yellow (constant 12v) wire comes from the 7.5 amp "BACK UP" fuse in the box next to the battery under the hood. Did you check that?
The antenna does not need to be connected.
because Jun 21, 2008 09:25 AM
Thank you!!! That was it!
macbeth18288 Jun 21, 2008 11:33 AM
really that antenna doesn't need to be connected?
gunz4me Jun 21, 2008 11:50 AM
ORIGINAL: macbeth18288
The antenna does not need to be connected BUT your FM reception will be extremely limited! With that said, I hate 98% of the local radio stations so that would be no loss to me if I were to lose my antenna connection.
macbeth18288 Jun 21, 2008 12:26 PM
Well, if you do hok up the antenna you need to get that adapter.
you can't just plug in the antenna into the back of the radio.
That's probably why you broke it
Richard Pardue Mar 10, 2019 02:22 PM
I had the same problem with my radio. I replaced the 7.5 fuse and it still isn’t working. QUOTE=mk378;568748]Power for the yellow (constant 12v) wire comes from the 7.5 amp "BACK UP" fuse in the box next to the battery under the hood. Did you check that?
The antenna does not need to be connected.[/QUOTE]
Richard Pardue Mar 10, 2019 06:14 PM
Yes I changed the 7.5 fuse also the radio fuse today but still doesn’t power on
[/QUOTE]i changed both the radio fuse and the 7.5 fuse
