cd player / turn signal
I have two problems here..
CD Player will not turn on.. I took out the old cd player which was working fine.. wired up the harness for the new one and the new one does not turn on. Took the CD player to Best Buy to test it and it works.. No blown fuses on CD Player or car.. any suggestions??
Right front corner light / turn signal does not work. The left works perfectly front/rear. The front right does it work at all but the rear right turn signal flashes really fast. Looking for info on how to fix that as well. Thanks
95 CIVIC EX
95 CIVIC EX
I would recheck the harness to make sure everything matches right with stock (red to red, yellow to yellow, black to black to start).
I wired the old cd player back.. plugged it in and no power. Fuses on cd player and under dash are good. Any ideas what is wrong? The clock is on but resets to 1:00 everytime if that helps. I have no idea what is causing the cd player not to work.
marcosv827
Aug 8, 2005 05:58 PM
burnoutNshootnos
Dec 22, 2004 10:30 PM
recheck your fuses under dash.
