A few questions.
Old Mar 31, 2005 | 11:01 PM
Orin's Avatar
Default A few questions.
How complicated is it to find a converter kit for an '05 Civic VP, will I need a wiring harness, what's the best way to run an amp power cable(going for as clean as possible here), and how easy is it to swap speakers out of the doors?
Old Apr 1, 2005 | 11:36 AM
Remmy's Avatar
Default RE: A few questions.
You are going to need a wiring harness and a dash kit... Metra normally makes it and they might not have it out for you whip yet... although if the '04 is the same then you can pick up a kit for your 05. The best way to run a power wire is thru your engine firewall and along and under the sides of your kick panels. Also put in a fuse between the battery and firewall of the car.
oldguy
Mar 17, 2007 01:03 PM
capn_midnight
Jul 9, 2005 10:57 PM
ThisWay84
Jul 2, 2005 09:21 AM
mitch_cox_kc
May 27, 2005 05:06 PM
foozball
May 25, 2004 11:56 PM
