Fiber glassin center console
I'm currently building a center console for my screen and a couple gauges... But uh heres a few pics of what i got done so far...
[IMG]local://upfiles/29418/6601FB7FA5B147B8B37028582B6BC80A.jpg[/IMG] [IMG]local://upfiles/29418/D2BE595E4C4D41AAAA11CDF3292C498A.jpg[/IMG] |
RE: Fiber glassin center console
What gauges are you using down there?
What methods are you using to smooth that, bondo? And what color are you painting that after it's done |
Pressure gauges for my airride, uh sanding, sanding and more sanding, and then probably black...
ah, I'd suggest bondo over it though for a better surface but that's just my 2 cents
if you mix your bondo with a little resin and then use your cream hardner it'll make a "milkshake" then spread it on thin and it will self level .... it saves alot of sanding..... i use this technique when i'm doing painted glass it works very well..... also if you need more strength try cutting little chunks of 2 oz chop mat and then mixing the mat in with your resin to make a paste.... then you can apply it to the inside of your project..... hope this helps....... lookin good so far
^^ Im pretty sure he already used body filler on it.
Huh thanks for the info, never herd of the "milkshake", lol...But yeah i read it a lil late its almost done now...And Yeah i'm using bondo but thanks for the two cents...
^ Just for the heads up next time, try using rage gold instead of bondo, its easy to work with, less air bubbles and sands easy...
hard as **** to find though
i never found it at lowes or home depot.. |
my milkshake brings all the boys to the yard, and they're like, it's better than yours....
[8D] I'll have to try that resin/filler thing next time I'm doing fiberglass work. |
