Fuse pops
Anytime I use my blinkers or tail lights it seems to blow a fuse. Im thinking I got a broken wire somewhere grounding. Where does the wiring run through from the front to the back for the lights? or do you have any other suggestions on how i can go about finding the problem?
the wiring runs down the drivers side so you are going to want to pull the door sill off and then start looking for damage to loom and corrosion, also in the trunk area remove the liner and start checking the wiring there. You may also want to remove the headlights and look at the wiring in that area, the front bumpe comes off really easy so it won't take long.
Well I couldnt find any broken wires but when I look at the rear speakers it looks like they are wired with new wiring and connecters and wired right into the tail lights. Do you think this could be the cause? Or is that normally how they are?
should be along the drivers side wiring harness in the trunk a grey one if memory serves, also check where the tail light wiring behind the tail lights, see if by chance the wiring grommet got pushed out and the wires are rubbing there.
