ground wire
Old May 23, 2006 | 03:22 PM
Ohiocivic's Avatar
Default ground wire
i have a 93 civic and im in the finishing process of puting in my system but cant find a good ground, this is the one thing i cant do very well is find a decent ground location so i was just wandering where everyone else is running theres??
Old May 23, 2006 | 03:42 PM
Street Sniper's Avatar
Default RE: ground wire
There are two big fat bolts in the rear corners of the trunk.
Old May 23, 2006 | 06:11 PM
mill$civic's Avatar
thats were i ran mine^^..it supports some metal under your car, i dident take it out all the way, just enoph to fit the loop underneath, you can also use the spare tire bolt
Old May 23, 2006 | 07:12 PM
Ohiocivic's Avatar
thanks u two, ill check it out tomarrow, didnt happen to see the two fat bolts in the corners when i gutted it but maybe i wasnt looking in the right place
Old May 23, 2006 | 07:50 PM
riceburner700's Avatar
yeah they hold your metal bumber support
Old May 23, 2006 | 10:07 PM
sillyredcivic's Avatar
A couple of finished panels over my rear strut towers and the bolts right there worked fine for me!!
Old May 23, 2006 | 10:10 PM
ef4life's Avatar
i just drilled a hole and put a bolt through it
Old May 24, 2006 | 11:23 AM
hmdaigle's Avatar
I also drilled a hole, and put one of the stinger ground bolts through it. Making sure to get out the Dremel first and cleaning off all of tha paint to make sure to get all body, and a good solid ground.
HD
Old May 24, 2006 | 10:35 PM
Fiirkan's Avatar
my step brother drilled a little hole and put a bolt through it... and i little piee of me died when he did that cause i just had the car for 1 week not even and we were drilling hole in it
xsdudztx
Aug 14, 2007 05:45 PM
xyz357
Sep 7, 2006 08:35 AM
khanselman
Aug 18, 2006 02:02 PM
:94CIV:DX:
Jul 21, 2006 09:33 AM
skytanker2003
Jan 9, 2006 11:45 AM
