HeadUnit Install Walkthrough
Old Apr 5, 2005 | 09:04 PM
AnakinKenobe's Avatar
Default HeadUnit Install Walkthrough
Need a headunit install walkthrough for a 95 ex civic, dont know how to put it in , pics would help tooo..... lol
Old Apr 5, 2005 | 09:10 PM
speedstream's Avatar
Default RE: HeadUnit Install Walkthrough
i had my **** installed by circuit city cause i have a 98 civic ex w/ keyless entry and the stereo works w/ the alarm so my stock unit is sitting behind the dash working with a 3-way wiring harness and i have a weird fitting so i needed a mounting bracket. i wanna put the stock unit back in and go with a slave cd player
Old Apr 6, 2005 | 12:43 AM
Roost3r's Avatar
basics to an install
tools- screw driver, splicers and or e-tape
first, go to wall mart or any place that caries car audio and by a wireing harness for your select car, the lists are on the back.
take that home
unscrew the center pannel covering the deck and unscrew the unit so u can pull it out, match up and connect the colors of the harness to the wires coming from the new deck. use wire connecters,sauter, or wrap with e-tape.
connect the plug from the harness to the plug froming from the car. then put it back and screw everything back and and yay ur done.
Old Apr 6, 2005 | 09:07 AM
sugerbear008's Avatar
ABSOLUTELY AGREE makes life a whole lot easier and you won't have to cut up you car harness.
Old Apr 6, 2005 | 10:16 AM
well how does teh dash pieces come off, i got the all the wiring finished up i just can figure out how to get all that plastic off...
Old Apr 6, 2005 | 10:24 AM
Mossy's Avatar
i was able to put mine in without taken the center plastic off. i wrote up a guide for Lucifer on how to remove the center console though, but its for 96-98
Old Apr 6, 2005 | 04:20 PM
Roost3r's Avatar
ill have to get back to you...try giving it a nice tug and see if anything wants to pop out
Old Apr 6, 2005 | 05:04 PM
Pete's Avatar
there are a few screws holding it on but theyre facing the floor so u cant see them......take those 2 out and then itll pop out real simply.
Old Apr 6, 2005 | 06:37 PM
Roost3r's Avatar
[sm=exactly.gif]
Old Apr 6, 2005 | 08:47 PM
can i see some pictures cause i didnt see any screws at all....
