HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   help with amp wiring (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/help-amp-wiring-58933/)
legal Jan 15, 2008 04:13 AM
i got the dual 750 wat amp. and it never goes off.
how do i wire it to where it goes off when my car goes off
lol im tired of having a dead car all the time :D haha.
&whats a good way to hide my wires.:eek:
My04Civic Jan 15, 2008 04:25 AM
RE: help with amp wiring
uhh...you should have the power going from your amp, to an inline fuse, then to the battery, and have a good ground coming from your amp as well. from what i know, the amp should turn off when your car turns off. that doesnt make any sense.
legal Jan 15, 2008 05:10 AM
its something with my remote wire.
its not hooked up right.
My04Civic Jan 15, 2008 06:10 AM
what color wire do you have the remote wire hooked up to? it should be hooked up to blue
mk378 Jan 15, 2008 07:08 AM
You need to run a single thin wire from the remote terminal on the amp to the "amplifier turn on" lead on the back of your head unit. Some RCA cable assemblies have the wire molded in between the audio cables. Usually it is a blue wire from the head unit but check your manual or the sticker on the unit to be sure.
Littlehag Jan 15, 2008 08:06 AM
If you have an aftermarket cd player it will be a blue wire comming out of the back of the unit. Normally it's blue, I can't say always because i'm sure there are some manufactures that just want to be different. as long as that's hooked up you should be good to go. check to see if you have power at the amp (remote terminal) when you turn the ignition off. If you do then trace the wire back to the head unit and see if there is a problem there.
imshirazy Jan 15, 2008 01:29 PM
ORIGINAL: Littlehag
It's actually always blue
YOu simply have power going through it of course
do as they say and trace it back to see where it's coming from
if there are no cuts in the blue wire, you may have an amp or HU problem
legal Jan 16, 2008 04:19 AM
what i got going on right now is i have 2 clear medium guage wires going into this 2 hole into 1 hole deal the 2 clear wires from 12v and rem. are pluged into the 2 holes and then the 1 hole is connected to the big thick blue wire that goes to my battery.
My04Civic Jan 16, 2008 04:24 AM
ORIGINAL: legal
dude...what the hell? we need you to post pictures of everything. there should only be these wires.....as follows: Ground, Power, REM(remote), and speaker wires, coming from your amplifier. ground to ground, power to inline fuse, to + battery terminal, REM to blue wire behind head unit, speaker wires to sub(s).
legal Jan 16, 2008 04:38 AM
haha i know its confusing me as well.
ill take pictures of it after school.
