Help installing Aftermarket CD player in 89 civic
I have a Jensen CD2010x that I need to install. I Spliced the wires together color for color but that didnt work. I had two wires left over from the car wiring Harness, the Orange/White adn the Light blue. I had one left over from the aftermarket wiring, the dark blue. The Wire color codes for the cd player are...
Red:Ignition Yellow: Battery B+ Black:Ground Dark Blue:Power antenna Gray:Right Front + Gray/Black:Right Front - White: Left Front + White/Black: Left Front - Violet: RR+ Violet/Black: RR- Green: LR + Green/Black: LR- I found this on another forum: 1988-91 Honda Civic Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White My question si What colors go to what colors? The Car harness has 13 wires, a Gray, Gray/Black, White, White/Black, Orange/White, Yellow, Red, Light Blue, Black, Green, Green/Black, Violet, Violet/Black. I think the color codes I found on the other forum are wrong. Any help? |
RE: Help installing Aftermarket CD player in 89 civic
ORIGINAL: ryank327 I have a Jensen CD2010x that I need to install. I Spliced the wires together color for color but that didnt work. I had two wires left over from the car wiring Harness, the Orange/White adn the Light blue. I had one left over from the aftermarket wiring, the dark blue. The Wire color codes for the cd player are... Red:Ignition Yellow: Battery B+ Black:Ground Dark Blue:Power antenna Gray:Right Front + Gray/Black:Right Front - White: Left Front + White/Black: Left Front - Violet: RR+ Violet/Black: RR- Green: LR + Green/Black: LR- I found this on another forum: 1988-91 Honda Civic Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White My question si What colors go to what colors? The Car harness has 13 wires, a Gray, Gray/Black, White, White/Black, Orange/White, Yellow, Red, Light Blue, Black, Green, Green/Black, Violet, Violet/Black. I think the color codes I found on the other forum are wrong. Any help? It was a bad idea to splice the wires. Use wire harness next time... they will let you finish the job in about 15 minz... if you know what you are doing... Orange/White = Illumination. AKA DIMMER Blue=Power Antenna |
| All times are GMT -8. The time now is 02:53 AM. |
