how do i install glowgauges??
Old Jul 3, 2006 | 09:32 PM
WhiteCivic15's Avatar
Default how do i install glowgauges??
got some glowgauges for my 94 civic hatch, i dont know how to install them and i obviously dont wanna mess anything up, so just wondering what i need to do. please reply asap!
Old Jul 4, 2006 | 06:14 PM
dfdon's Avatar
Default RE: how do i install glowgauges??
what aspects are u unsure of? How to make em glow? or what let me know
Old Jul 4, 2006 | 07:42 PM
well, i need to know what i need to do to install the gauges and what to hook them up to so they glow. im new at this:-/
also, i had a couple other questions noone responded to. ive got the 1.5 16v motor in my car w/ the header off the 1.6 v-tec motor, and have absolutely no power till 3000 rpm because of this, and i was wondering if putting on the stock header would fix this (it has a full catback exhaust as well). quick reply would be greatly appreciated, thanks!
Old Jul 5, 2006 | 11:04 AM
Remmy's Avatar
I will respond properly when I have the time later. Dont move. Its really inportant what Ill say.
Old Jul 5, 2006 | 12:23 PM
OpTiCaL's Avatar
ok, so you are just wonderin how to wire em up... well most of the time you can hook em up to the fuse box or wire it inline with the cigarette lighter. if you have a volt meter it will be able to tell you what connections are live.
as far as the engin goes, dont really know. i would look up all the info on the engine and mods to it to see if you can find out why they would swap the head. a little bit of reverse problem solving.
Old Jul 5, 2006 | 07:10 PM
wouldnt i want to hook them up to the headlight switch so they come on when i turn on the headlights??
Old Jul 5, 2006 | 10:35 PM
dfdon's Avatar
sure you can do that a lil more tricky but doable
Old Jul 6, 2006 | 11:29 AM
Remmy's Avatar
Ok.
When applying glow gauges you must be very careful. There is no room for screw ups. Its like heart surgery. You need to have 100% confidence and plenty of time on your hands to do this. Take the two screws out of the bezel and then find the screws to remove the cluster. You also want to carefully remove the plastic sheild over the cluster. Now when you go to install the glow guages, find out if they have enought room in the center so it wont cause a needle to fight it. I had to trim mine a little bit by using an Xacto knife. the needle slightly hung back off of the cirlce (for looks i guess) and I trimmed it enough to where I could slide the faces over the neddle.
DO NOT pull on the needles. They will not come off but if they are forced they wont work. Carefully slide the faces over the gauges and you will be ok. Now just stuff the wiring away and you are set. Take a test drive to see if you havent screwed up your cluster.
P.S. I wired mine to the 12v socket.
Old Jul 6, 2006 | 01:37 PM
OpTiCaL's Avatar
ORIGINAL: WhiteCivic15
whats it gunna hurt if they are on all the time? they are most likely EL lit and those last for freakin ever so no harm there. My 03 has EL gauges and they are always on. The only thing is when i turn on my headlights they dim down to the brightness i have them set to.
Old Jul 6, 2006 | 05:38 PM
Remmy's Avatar
^ what he said. They dont use bulbs. I like mine lit all the time so that way when you go into a tunnel they light up or somewhere dark like a parking garage.
Im pretty sure that once mine actually do die out I will be a long time owner of another car.
