HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   how do i take this off? (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/how-do-i-take-off-61481/)
bigmikew1 Feb 26, 2008 08:02 AM
i wanna change the bulb behind it because it blew
[IMG]local://upfiles/14586/93D7955485284AB4A4B14685B9BC7E81.jpg[/IMG]
Stumasters Feb 26, 2008 03:22 PM
RE: how do i take this off?
The entire bezel, or just the AC/heater controls?
On my 97 the only way to get the heater / ac controls out were to take off the lower "neck" if you will, under the dash there, and look up at screws holding it in there. There was one lower and 2 on each side of mine, so 5 total, that you had to unscrew from the back. It takes a little blood and sweat.
You basicly have to be lying upside down looking up at the stuff up there with a flashlight.
bigmikew1 Feb 26, 2008 08:22 PM
yea the heater, a/c controls. errrr. ill take a look tomorrow and see.
danomatic93 Feb 27, 2008 12:23 AM
To remove the Heater Control Unit, first remove the lower dash console, then remove the radio. Then to remove the Heater Control Unit, there are 2-3 screws holding the unit on the front of it. So, squeeze your body with a flashlight to see where they are. There is another easy to see screw on the back bracket of the unit. Also, CAREFULLY, remove the hot-cold pull wire.
