How to hook up gauges: oil/engine temp, oil pressure
Old Apr 23, 2007 | 11:21 AM
FlipHKD720's Avatar
Default How to hook up gauges: oil/engine temp, oil pressure
Anyone have any tips on installing aftermarket pillar gauges, such as oil temp, oil pressure, or engine temp? My engine temp on my stockcluster is broken, so thats why im interested in getting a new one.When i get my triple pillar pod i'm getting voltmeter, tach, and then one of those three. Any recommendations on which one to get, as in which one would be most useful, and any tips on how to hook it up?
Old Apr 23, 2007 | 12:06 PM
dfdon's Avatar
Default RE: How to hook up gauges: oil/engine temp, oil pressure
i think oil temp and pressure are great to have especially if you are boosted like myself...voltmeter is good to if uve got alot of audio and video goodies...i have volt, oil pres, oil temp, air fuel, and boost all were pretty easy to hook up..let me know if u need to know how to install specific ones
Old Apr 23, 2007 | 01:13 PM
FlipHKD720's Avatar
oil pressure would be useful, i know how to do the volt and tach and kind of an idea about the pressure, but not really sure. It'd be an electrical gauge, not a mechanical one with extra oil lines ran into my interior.
Old Apr 24, 2007 | 11:08 AM
The gauge will come with instructions
Old Apr 24, 2007 | 11:36 AM
FlipHKD720's Avatar
even ebay ones? or are the Autometer gauges that much higher quality than the ebays? My friends got any ebay tach and voltmeter and they seemed to work jsut fine...
Old Apr 24, 2007 | 11:49 AM
yup, even the ebay ones. I used Glow Shift gauges and both came with instructions and wiring diagrams
Old Apr 24, 2007 | 11:51 AM
FlipHKD720's Avatar
nice, the GlowShift ones were the ones i was lookin at thanks for the info Tony
Old Apr 26, 2007 | 11:12 AM
The glow shift gauges aren't entirely accurate, and I will not be running them on my next setup. They're alright for n/a "look cool" goodies, and will be ~90% accurate for the most part.
Just do NOT get the tinted ones. They're impossible to see during the day when the sun is on your drivers side and/or behind you
Old Apr 26, 2007 | 11:22 AM
mill$civic's Avatar
I have oil and volt. Volt is so easy. Just hook it up to a 12v. And oil is a pain in the ***, you need to get behind your block and pull out the oil pressure sensor (mine is right above the oil filter on the d16y7)and install the new sensor with the wires hooked up to it that run to your gauge. It took me a wile.
Old Apr 26, 2007 | 11:24 AM
danomatic93's Avatar
June 2010 ROTM
where do you get the new sensor w/ wires for the gauge??
