I got this flip out monitor head unit
ORIGINAL: Sigracer10
i've never seen one that was able to bypass the parking brake by programming it, because itsa legality thing. they only way I know of to bypass them is to run a switch in line with the parking brake wire and hook the other side straight to a ground. that way, one side of the switch will allow the video to play while driving, and the other will not. That way in the incident that a cop pulls you over or whatever (i have heard of this happening on a few occasions) you can flip the switch so that it will not play the dvd. which results in no ticket. sounds crazy but i know people that this has happened to.
ORIGINAL: ic892003
u can bypass it, go back to the guy and tell him to bypass the parking brake because u want it on while u can drive
the pink wire just needs to be hooked up to a ground. so if you want it to play all the time just ground the pink wire to the chasis anywhere, or just to the ground wire in the radio harness.
here ya go
forum.ecoustics.com/bbs/messages/4/278797.html
iv'e used it and it works very well...use at your own descresion
on the jensens you have to use a switch or do this bypass once and your done
ORIGINAL: Vince22
thanx bro that thing actually worked
i still recommend putting a switch in line with that pink wire just so that you can flip it and make it appear legal and display the you cant use this while driving message, then when you want to use it jsut flip the switch the other way and it will play
ORIGINAL: Vince22
slovic94
16
Jan 9, 2008 09:31 AM
