interior lighting
In my car I have two neon tubes under my dash, and an L.E.D. Strip in my gauges, and are all wired together. Im using the switch that goes in the cigarette lighter, but I'm wanting to know how to wire them into the fusebox under the dash.
Also, does the dome light have a bulb or a LED? I wondering if it could be changed out to a colored LED, or if anyone else has done that.
ORIGINAL: PhillipBurch
ya 96-00 has no problem slaping in a led light in the dome... tho 92-95civic wants to keep the leds slightly ON... not enough current draw for them to fully turn off
as to the adding lights its very simple. first get a inline fuse holder and fuse of course, then use a spade female crimp conector and crimp it onto the fuse holder you just bought, and plug it into the fuse box directly... depending on which slot you put it in if its lite all the time or only with the ignition turned on... i cannt remember exactly.... but im pretty sure the one on the far left is powered all the the time. and run the other wire output from the fuse holder to your switch and then to your lights.
and then for the ground just find anything bare metal under the dash and find either a stop flat to use a self taping screw, or use a existing bolt/screw to ground your lights. very simple!
ORIGINAL: addiction2bass
mine never did!
in my 94ex
but in my 99 it works perfect... tho i do have a few leds that have burnt out over the 2years ive had the led unit. so i do need to replace it. i just have to use something else. im gonna go with white and super bright! oznium dome light units... not sure which unit to buy yet. i have yet to measure it out to find what will fit just yet.... im think about the ultra thin one since it probably would be the best due to thickness.
this is my old 94s ex dome light below.
door open
door closed
in my 94ex
door open
door closed
i have the ultra thin dome leds from oznium. i have the led's and it fits perfectly i can also have the dome light cover on. don't think that you can have the cover on with the other models. i went with the 1" x 1.5" led's
mine never did!
in my 94ex
door open
door closed
mine never did!
in my 94ex
door open
door closed
But as for the dome light, I was using an Oznium dome light and it turned off all the way. Maybe the Oznium ones will work in the EGs but not a regular LED bulb like you were using.
ORIGINAL: sfazngiants
ya mine was just a regular led bulb.... it works fine in my 99 because they are the same but my 99 is white... alot larger than stock... i just had to bend the metal tabs larger
