Looking for a awsome sub
Hey guys I'm looking for a kick A** sub, have any of you heard anything about Crystal brand? My friend told me he knew a kid that had one and it was wickid as hell. I'm looking to get a sub that will hit hard, reason being i listen to rap. I'm looking to get their 12" competition sub which will cost about $239 from a site without shipping.
Here are the specs:
Fs 28.6 Hz
QMs 5.9
VAS 2.68 cu ft / 75.9 Liters
CMs 74.61 in / lb / .207 mm / N
MMd 5.04 oz / 143 Grams
Xmax .55 in / 14 mm
Qes .37
Re 3.3 Ohms
Z 4.0 Ohms
BL 15.4
Pe 1000 Watts
Qts .35
SPL 88.6 dB
Voice Coil Diameter 3.0" Diameter / 76.2 mm
Displacement .13 cu ft / 3.68 Liters
Mounting Depth 7 3/8" / 187.3mm
Let me know what you guys think is the best, or tell me what you use Thanks.
Here are the specs:
Fs 28.6 Hz
QMs 5.9
Xmax .55 in / 14 mm
Qes .37
Re 3.3 Ohms
Z 4.0 Ohms
BL 15.4
Pe 1000 Watts
Qts .35
SPL 88.6 dB
IT sounds wonderful. One of the better subs I have had. Those guys know what theya re doing. But it exclusively to them SO it is going to be way cheaper. If you dont like it, they will gladly take it back. Of, the sub has an aluminum cone too [8D]
ORIGINAL: ef4life
if you want window breaking bass look into a MTX jackhammer, it weighs 350 pounds and is like 20 some inches diameter. but i really like JL stuff for the clarity and craftmanship
Sometimes I really wonder if people are serious with suggestions like that. I just assume they are being sarcastic considering the MSRP on that big pos is almost $8,000
Ascendant Audio Arsenal 12"
^^^ That will dominate that dayton(which is pretty awesome for the price) sub in both SQ and output. Hell of alot better then that crystal sub.
ORIGINAL: bobbytonic
ORIGINAL: ef4life
