m-12
Old May 20, 2006 | 12:01 AM
Josh's Avatar
Default m-12
R powerbass m-12 subs god
Old May 20, 2006 | 02:15 AM
bobbytonic's Avatar
Default RE: m-12
Good for a $50 sub
Old May 22, 2006 | 01:19 PM
Josh's Avatar
Default RE: m-12
SQ or SQL or SPL
Old May 23, 2006 | 08:23 PM
Josh's Avatar
Default RE: m-12
would the m-12 be god in a bandpassbox
Old May 23, 2006 | 09:55 PM
Josh's Avatar
Default RE: m-12
bump [sm=pcwhack.gif]
Old May 23, 2006 | 10:11 PM
sillyredcivic's Avatar
Default RE: m-12
Its a good cheap sub that will work well in just about anythjing you want to put it in. Its a cheap sub, it makes bass, thats about all I can say about it.
Old May 23, 2006 | 11:04 PM
Josh's Avatar
Default RE: m-12
OK. I found the phoenix gold r12 thea have A blue led light ring in the middle
thea would look sweet in mi bandpassbox r thea any god
Old May 24, 2006 | 12:28 AM
bobbytonic's Avatar
Default RE: m-12
Never...ever...put a subwoofer in a bandpass box built by someone other then a very skilled acoustic engineeer. They are one note fart boxes and will make just about any sub sound like *** unless designed perfectly.
Now Josh, myself and the other audio guru around here have both recommended subs that are very good, we have even told you amps and enclosures to go with them. If you want some crappy subs, then frankly go down to best buy and pick up the dual box set. Other wise stop picking out these low line garbage subs and listen to our recommendations.
Old May 24, 2006 | 08:12 AM
Remmy's Avatar
Default RE: m-12
^ Ditto. Dont ask if you arent going to listen.
Old May 24, 2006 | 11:21 AM
amg6975's Avatar
Default RE: m-12
www.epinions.com
look stuff up.
