more questions involving setup
boss 5 ch amp
boston acoustic speakers all around
my amp has input level settings for speakers and sub and low, high, full pass switches for speakers. What exactly would input level do and what should I set the pass switch for the speakers?
If the main speakers are all coaxial speakers(2,3,or 4 way-all in one speakers) run those channels full.
Sub Low pass..
Input raises the voltage on the incoming signal. DO NOT turn this all the way up........
I usually try turning the stereo up around 3/4 or so and then adjust the input level to be Loud. Does the amp have a light or something that will show it clipping? You don't want to PEAK the amp out all the time. I'm no pro by any means. But I did sleep in a Holiday Inn Express once.........
Sub Low pass..
johnwohl
Jan 9, 2008 07:34 PM
TeamExodusPres
25
Apr 21, 2007 12:40 PM
