no power to subs
i have 2 12 inch memphis subs powered by a memphis amp and i just built a box and now i hook em up and theres no power comming to the amp they have worked before idk what is up with it ne one give me a clue
RE: no power to subs
what ya mean?
no power going into the amp OR from the amp to the subs? either you blew your main fuse under the hood OR turn on switch from the radio.... or ya forgot to wire up the subs right.... |
the power light on my amp isnt going on and therefore subs arent working
do ya have a light tester or anything to check if your amplifier is geting a power sourse or remote turn on signal? or check the ground...
if it worked before ya swaped the box... look for anything that you moved or went ontop of..... |
ughh so frustrating!!!! does a distribution block that bring power from the battery to the block to another cable to the amp have to be drilled into metal
