ok im stuck im almost done
I have everything hooked up except the power cable i don't know where to put the fuse !!!! And i cant really make it far other wise i'll run out of cable ... Any 7 gen's know a spot to stick it
iasca is a sound comp organaztion. the reason you need to keep it close to the battery is the less distance between the fuse and the battery the less chance you have of a dead short...example... if it's run improperly and close to any sharp edges like hood hinges and doors or through the fire wall without a grommet.that way when you have a short your fuse will blow.. but if your short is between the fuse and the battery you'll have some smoke and fire..not good.
i dont like mounting them on the battery cause if it happens to rattle loose thers a bigger chance of arching the teminals together.
