problems with my 2001 Civic odometer 888888 and gauges
Hi,
I have a problem with my gauge cluster. I read a lot about it but I couldnt find an answer yet. Sometimes the odometer shows TRIP AB 8888888 and sometimes everything works fine. Also all the gauges sometimes just die meaning that everything marks 0. Temp, gas RPM and Speedometer..
All the lights in dash work fine.
I have noticed that when the problem occurs (usually when put the ignition) the battery light blinks intermintently so I think that it could a grounding issue.
However I have cleaned almost all the contacts under the dash and checked the wiring.
I think that It could be any conector under the hood.
Any advice will be helpful.. I am really tired of been dealing with that problem.
thanks
thanks
I ended up replacing the instrument cluster with one from a Junk Yard.
Only problem I have now is the new Cluster Mileage reads way higher than my last one.
I am not sure if you can reset the mileage or if the PCM has an auto configure that will load the correct Mileage. Any ideas on that would be great.
You may call up some dealers and see if they can reprogram it for you, which if they can do, I'm sure they won't do for a small fee
. Otherwise, you can always keep checking eBay or recycle yards for used clusters and find one that most closely matches yours for mileage...
Hi,
thanks
thanks
KLK99CIVIC
Sep 5, 2010 05:14 PM
OHCivic
Feb 7, 2010 06:43 PM
swimerskidude15
Jun 5, 2007 06:09 AM
bmxchickie
Jun 4, 2007 09:58 PM
