HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   problems with my 2001 Civic odometer 888888 and gauges (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/problems-my-2001-civic-odometer-888888-gauges-84185/)
vivicho Jul 19, 2010 09:22 AM
Hi,
I have a problem with my gauge cluster. I read a lot about it but I couldnt find an answer yet. Sometimes the odometer shows TRIP AB 8888888 and sometimes everything works fine. Also all the gauges sometimes just die meaning that everything marks 0. Temp, gas RPM and Speedometer..
All the lights in dash work fine.
I have noticed that when the problem occurs (usually when put the ignition) the battery light blinks intermintently so I think that it could a grounding issue.
However I have cleaned almost all the contacts under the dash and checked the wiring.
I think that It could be any conector under the hood.
Any advice will be helpful.. I am really tired of been dealing with that problem.
thanks
RonJ Jul 19, 2010 10:55 AM
Have your alternator tested.
chrismag Jul 19, 2010 12:47 PM
ronj my maintenance light flashes..i have a 2002 civic, it just started the other day, what could it be?
OHCivic Sep 16, 2010 04:33 PM
Had the exact same problem
I ended up replacing the instrument cluster with one from a Junk Yard.
Only problem I have now is the new Cluster Mileage reads way higher than my last one. :eek:
I am not sure if you can reset the mileage or if the PCM has an auto configure that will load the correct Mileage. Any ideas on that would be great.
mach1racer Oct 11, 2010 04:11 PM
I think you can take it to the dealer and they can set it for you.
FORT342 Dec 30, 2010 06:57 AM
You may call up some dealers and see if they can reprogram it for you, which if they can do, I'm sure they won't do for a small fee :(. Otherwise, you can always keep checking eBay or recycle yards for used clusters and find one that most closely matches yours for mileage...
eltaber Apr 24, 2015 12:49 PM
resolder contact points.
Originally Posted by vivicho (Post 726816)
Hi,
thanks
The contact solder points in your instrument cluster are loose, you need to remove your cluster remove the white plastic cover and resolder the 12 conector points that are by the wire harness plugs.
itburnswhenIP Apr 24, 2015 11:12 PM
check thread dates bofore you post its 5 years old.
