Removing the Rear Deck on a 97 Civic DX
Old May 31, 2006 | 04:35 PM
Vadagar's Avatar
Default Removing the Rear Deck on a 97 Civic DX
I have the DX model, so the DIY doesnt work for me, only one half of the seat comes down in my car. The other half, it seems is bolted to a metal latch type thing. Has anyone successfully removed their seats and had access to under their rear deck on the 96-98 civic dx?
I want to put this eDead in it but i just cant get it up.
Old May 31, 2006 | 05:21 PM
mill$civic's Avatar
Default RE: Removing the Rear Deck on a 97 Civic DX
humm im not sure if its the same as a 2000 model..but do you have the key thing on the top of your rear deck to open the back seat? if yes, turn the key one way to open one half of the seat, and turn the other way to get the other side open..if not..thos pull tab things in your trunk under your rear deck, pull thos and push the seat and it should open, thos are the only 2 things i can think of..unless the 97 seat dosent open all the way[&:]?
Old May 31, 2006 | 08:20 PM
Zergo's Avatar
ORIGINAL: mill$civic
I have a 97 Civic DX as well and this is exactly how it works. Sometimes you gotta jiggle it a bit though, but not excessively.
Old Jun 1, 2006 | 10:52 AM
sillyredcivic's Avatar
Once you have the seat down, remove them from the vehicle. Next you want to remove the rear quarter panels. I have found you can take one side out and then work the rear deck off, but taking both out will make it much easier to work with. Then remove the rear deck and TA-DA!!!! You have access to your rear speakers!!! Figure on spending about an hour on the whole ordeal with installing the speakers and everything and putting it back together. It isn't much fun, but hey, its better than dealing with stock tunes!!!
Old Jun 5, 2006 | 01:55 AM
TrAvMaNFTW's Avatar
mine is a 96 dx it that helped trust me it will work for you if i'm lying, i'm crying, i aint shed a tear
Old Jun 5, 2006 | 07:56 AM
Remmy's Avatar
Is this a coupe or a 4 door? IF its a sedan its exactly the same thing as the DIY I wrote.
Shbek
May 9, 2009 11:14 AM
xxeddixx
Aug 24, 2006 05:06 PM
aliefnate
Mar 14, 2006 02:15 PM
n8te81
Mar 5, 2006 01:40 PM
vmf
Jul 22, 2005 11:18 AM
