HondaCivicForum.com
-   Audio/Visual & Electronics (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/)
-   -   speaker fit (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/speaker-fit-44933/)
Thefbomb13 May 22, 2007 09:58 PM
speaker fit
I did a search for this and came up with nothing ... But i'm planning to get some 6.5s are they gonna fit perfect cuz i hate messing around with crap like that i hate cutting and whatever but Do they fit right in place and just screw?? Cuz in my camaro it said that my speakers were 6.5 and i got 6.5 but the stock speakers were oversized 6.5s how dumb ?!?! right ?
cderalow May 23, 2007 04:38 AM
RE: speaker fit
if you don't want to cut or anything, you'll need 6-1/2" shallow mount speakers.... if you don't mind cutting, any 6-1/2" speaker will fit
Thefbomb13 May 23, 2007 11:58 AM
RE: speaker fit
ORIGINAL: cderalow
Where can i get these shallow mount speakers??
cderalow May 23, 2007 12:07 PM
RE: speaker fit
you'll have to check the speaker's top mounting depth, but i believe it needs to be less than 1-5/8" to fit without cutting out the back of the bracket
really with a dremel, it should take you less than 5 minutes to cut out the bracket behind the speaker mount...
Thefbomb13 May 23, 2007 01:41 PM
RE: speaker fit
i'll probably end up just doing that i don't want to but i will lol thanx i need to buy a dremel ..!!! lol
mlobitz May 24, 2007 03:53 AM
RE: speaker fit
You could probably make an MDF baffle and bring them out a little too, without interfering with a factory fit. Take a good look at it before you buy the speakers.
Thefbomb13 May 24, 2007 09:22 AM
RE: speaker fit
MDF Baffle??
Chopsta May 24, 2007 10:55 AM
RE: speaker fit
ORIGINAL: Thefbomb13
MDF Baffle??
MDF is a type of wood usually 3/4" thick. Make a bracket/baffle so the speaker sits on top of the MDF. The MDF will bring the speaker farther out make it fit.
Regularly it would be just the metal on the door then speaker.
With the baffle it would be, metal on the door, homemade bracket, then the speaker.
It just gives you an extra 3/4" clearance.
It's not hard to make.
the727kid May 25, 2007 11:21 PM
RE: speaker fit
MDF Baffle should be used in ANY speaker install. Increased mid-bass response.
Thefbomb13 May 27, 2007 09:45 PM
RE: speaker fit
oh word they don't make em i'd have to make it ?? i mean its no problem it would just be nice to save some time lol seeing how i don't have the right tools to cut wood
