Stereo / Keyless Entry
Old Nov 27, 2004 | 06:45 AM
31valestreet's Avatar
Default Stereo / Keyless Entry
I have recently bought a 2 year old Civic I want to change the factory head unit, but i have been told it can effect the keyless entry system as the head unit recieves the signal. is this right??
Matt
Old Nov 27, 2004 | 10:18 AM
no9t9's Avatar
Default RE: Stereo / Keyless Entry
I've never heard of a keyless entry system hooked up to the radio before. The keyless entry system is its own sperate module which has different radio frequency "channels" to control different things depending on which button is pressed. Maybe this is the confusion? I highly doubt that the dealer would wire up your keyless system to your head unit. It just doesn't make sense. the keyless entry system is not part of the head unit... unless yours isn't factory and someone wired it up funny.
Edit: I have a 99 civic which had a factory head unit and factory keyless system. I replaced the head unit (twice) with no problems to the keyless system. (I never even thought about it).
Old Nov 27, 2004 | 10:32 AM
green98lxsedan's Avatar
on the 96-98 i know for sure the keyless entry goes through the head unit.
i am not sure about anything newer but i don think so.
Old Nov 29, 2004 | 11:14 AM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Nov 29, 2004 | 12:56 PM
bethany138's Avatar
Hi,
There is a special thing made...a T connector. It will allow you to hook up your AM headunit (in dash) and hide the stock headunit behind the dash with both connected.
This will allow you to have a new headunit and keep your keyless entry.
Aside from that, I would recommend you get a good alarm (which usually come with AM keyless entry) when you replace your radio anyway. Safety.
Hope that helps.
little b
Old Nov 29, 2004 | 09:20 PM
Default [Deleted]
[Deleted by Admins]
Old Jul 26, 2005 | 07:56 PM
civilcivic's Avatar
I have a 98 Ex with a aftermarket radio and the keyless don,t work.
I was told by many stereo shop that the alarm and keyless runs throught the radio.
Old Jul 26, 2005 | 11:29 PM
LEVIII's Avatar
ORIGINAL: civilcivic
This is in fact 100% true. You can still add an aftermarket keyless though.
Old Jul 27, 2005 | 02:01 AM
superballa22's Avatar
Fact 96-98 entry work with radio...anyother year does not...aftermarket radio no keyless entry...but u could always buy a cheap one for 30bucks if u dont want to unlock ur doors urself that bad
junderland
Nov 27, 2011 04:26 AM
jgar2626
Mar 3, 2007 12:34 AM
civilcivic
Jul 27, 2005 12:05 PM
[96civic]
Jan 4, 2005 08:09 AM
Korks101
Oct 18, 2004 03:44 PM
