subs missing beats
hey guys,
my sound system is below, if it mattters, but my problem seems to be when i turn up the volume on my headunit my subs miss more and more beats, wondering why this is ive tried every thing with the equilizer and it seems to help a tiny bit do i need a new battery or is it always like this thanks for the help.
john
john
If it isnt playing them as it gets turned up...I wonder maybe what is the filter setting? 80hz 100hz? (if you have that adjustment) I've had 10's before and when turned up they didnt hit all the notes, cause they didnt have the range. Thats why I've stuck with 12's, they are far more versatile imo.
Your subs are drawing too much power from the amp.....the amp shuts down automaticly so that it doesnt overheat/blow up. You need to turn the bass setting down, or get another amp, and run seperate amps on each sub. Turn the stereo up and go look at the amp, I bet you there is a little red light coming on that says "Protect"..........
ok so i dont understand all of this but so far i turned down the bass boost on my amp so i can turn up the volume louder although the subs wont be as loud, and i dont understand the .5 or 1 ohm could you explain more?
thanks for all the help guys got it fixed i got much thicker gauge wire to run from the amp to subs and it works much better also got some awesome kicker speakers that sound great
It could also be the amp you have. the amp isn't able to catch all of the bass lines so it doesn't push them out. It could either be a filter that needs to be tuned. Or the amp can't handle the frequency. Does that sound possible or no??
