What does it do?
Old Sep 3, 2009 | 01:06 PM
jpnolan's Avatar
So please tell me how you plan on hooking up a sub to a stock headunit. I'm pretty sure you need an aftermarket headunit for hondas. I've hooked up 3 car sound systems and have never been able to use the stock headunit.
Old Sep 3, 2009 | 01:09 PM
^Tap into the rear speaker wires with your RCA cables and use an amp with a built in low-pass filter.
Old Sep 3, 2009 | 01:28 PM
have you tried to follow the wires to see what it goes to?
Old Sep 3, 2009 | 01:36 PM
JPark's Avatar
Got one
Old Sep 3, 2009 | 01:37 PM
JPark's Avatar
It appears the wires hooked to it run from both the speakers and the lights, and one line runs up to the battery
Old Sep 3, 2009 | 01:39 PM
I am almost certain it is some kind of grounding device. Probably there to filter noise out of the stereo system to reduce static, etc.
Old Sep 3, 2009 | 01:41 PM
JPark's Avatar
That sounds like the most likely, now that you mention it...
Old May 18, 2022 | 11:29 AM
lcstyle's Avatar
it's a coil assembly for the glass antenna
Hola
Sep 11, 2007 07:17 AM
D16z6
Oct 15, 2004 04:50 PM
White_Devil
Sep 28, 2004 05:42 PM
ohbiskits
Aug 1, 2004 09:43 AM
