What wires do I need for my system?
Ahh you made me think on that one pad one
2 feet ????? negative ghost Ryder
MECP evan says the fuse should be 12 to 18 inches from the post i suggested 12 inches because of the civics small battery
you can go to MECP.com to verify it
ORIGINAL: ef4life
the fuse should be 1-2 feet from positive battery terminal, you made a mistake in your post. but very detailed and you know what your talking about.
Hahaha yea i did, dang OK it was late and a long post but good looking out
ORIGINAL: ef4life
dukat03 in your first post you said the fuse should be 12 feet away, i was simply stating you made a mistake and should be no more than 1-2 feet away.
hope this works for you
[IMG]local://upfiles/16447/246484C3D8054458ACE4381D41AC3B2C.gif[/IMG]
[IMG]local://upfiles/16447/52BE1FDA5AA8405795BDCC5A0592F535.gif[/IMG]
[IMG]local://upfiles/16447/C2869F32822240A2BF4F7C142C61B033.gif[/IMG]
[IMG]local://upfiles/16447/18E9F523F3324D06BA3307B23E9F2D7A.gif[/IMG]
IF YOU WANT TO PULL THE DOOR OFF PART
on some civics depending on month of the car , the speaker grill needs to be removed and the screws that are hidden are behind it
when you pull all the screws and wires snap the door panel apart from the door beging from bottom to top .
pull up on the door to release it from the window seal and its off
