Tutorial: Wheel Chop Using Photoshop
9 Attachment(s)
Mods maybe this tutorial should be stickied.
There's many of you guys that ask for wheel chops and some of you guys might have Photoshop so here's a tutorial for doing wheel chops. There are many ways to chop wheels, this is my way that i use to do wheel chop. I am using Photoshop CS. Remember: The better and higher the resolution the better the outcome will be. For best results find cars that are at the same resolution and as close to the same angle as possible. Also, for best results, DO NOT use the same wheels for the front and rear. Use the front wheels for the front wheels and the rear wheels for the rear wheels. Find Donor Wheels Pictures. The sites that i like to looks for images are google, flickr, and bing This is the car that i will be doing the chop on. I will try to be as detailed as possible. Attachment 14473 1) Open Up your car you want the wheel chop AND the donor wheels pictures opened on photoshop Attachment 14474 2) Select the "Elliptical Marquee Tool." You might need to right click the option and select it Attachment 14475 3) Make a Circle. Right Click and Select "Transform Selection" Attachment 14476 4) Drag the Corners and stretch it or rotate it so that the circle perfectly outlines the wheels. After you get that right, Press the "Enter" key Attachment 14477 5) Select the "Move Tool" and drag the circled wheel onto the car that you want the wheels on. Attachment 14478 6) Press "CTRL + T" to free transform the wheel that you've just dragged. Scale, Rotate, and or drag the wheels till they fit over the original wheels. Pretty much similar to step # 4. AND Press the "ENTER" key. Attachment 14479 REPEAT STEPS 2-6 FOR THE REAR WHEELS Here is what you will end up with Attachment 14480 NOW... if you want to save the picture. Click "File" --- "Save As" . Rename It. and In format select in the drop down menu "JPEG" or whatever format you want to save it in. and click "Save" and click "OK" And there you have it. Attachment 14481 ENJOY this tutorial and good luck. Hope this helps many of you guys and if i get enough interest in this thread i will make a tutorial for lowering a car as well. |
great job (Y)
