washing a black car
ORIGINAL: ic892003
wat products do u reccommend using to keep black paint fresh?
(1) Like Pwnedu mentioned, never use car wash brushes. This will bring certain death to any paint. Scratches and swirls detract light from a smooth, deep, glossypaint finish.
(2) Never let you cardry in the sun, this can cause waterspots that bake into the paint surface and weakens the clear coat resulting in a less effective barrier between the paint and environmental contaminants/sun. If at all possible, dry your car in the shade.
(3) Always use clean, quality,microfiber, waffle weave, or terry towels for drying. If using a drying blade of some sort, make sure no debri gets caught on the blade and drug across your paint surface.Many also use leaf blowers to blow dry the surface as well to avoid any paint contact.
(4) Never wax on top ofdirty paint.
(5) Keep microfiber towels andquick detailer spray handy for in between wax care.
(6) Never bear down on your paint with towels (whether washing or waxing) Use moderate to light pressure as if you're cleaning a CD. Paint respondsto textures and pressure similarly to thesurface of a CD.
(7) Use a quality microfiber, sponge, or chenille mit to wash with. Do not washpaint with the same towelyou wash your wheels with. Again, light pressure...
(8) Clay your car at least once a year.
If you practice these simple, gentle habits, then just about any decent product will protect your finish from the enviroment. But no product can protect your paint from you if bad habits are developed! Check around the DIY and detailingthreads here for good product suggestions. Everyone has their own preferences, likes and dislikes. Autopia.com, Autogeek.comare alsogood reads.
It's not the product, but the process...
^ Yes a brushless car wash will do just fine at times. Butall too often,your car will get dirty enough to where some type of towel or mit will be necessary to remove all the dirt. Car washes are bad for leaving tons of dirt behind, then people dry their cars offrubbingdirt particles all over theirpaint scratching it. Ever wash your car and let it dry only to seemost of the dirt still there? [:@]So yes,more often than not,you'll have to do it yourself. Sponge, rinse bucket, soap bucket, hose. One or two panels at a time, remove suds with hose at regular pressure to sheet off, opposed to spraying. Spraying increasesthe likelihood of water spots.
ORIGINAL: ic892003
hey jake did u repaint ur car???
