water marks killing me
If there permanent then you will have to give the car an acid bath using hydrofluoric acid but I would have some one do this that knows what there doing I had a friend that faded run marks in to a focus it looked like it had tiger stripes.
The focus wasn’t his it was are dealerships we have done a lot of acid baths to cars and he thought it would be faster to get the whole car wet and spray the whole car down instead of doing one section at a time. I told him it might be a bad idea but he didn’t want to spend the time doing it the right way.
All good advice above.. I might add that Meguiar's scratch X does a pretty good job. Other than that, I've used distilled vinegar with good success. This is not always successful depending on the depth of the water spot etching. The quicker you get it off, the better. If it bakes in the hot sun for a week or two, you're in for a challenge... also depending on the protective properties of the wax on your car at the time. Good luck removing them.
Another good trick in addition to a great drying job and detailing spray is not using a hose attachment and just using the hose and just put it over your car, gravity will take good care of the lil water spots a nozzle can cause.
khanselman
13
Nov 6, 2006 06:28 PM
