Automatic to Manual OBD1 ECU Conversion
This is a pretty simple procedure. If you have any experience in soldering, the right tools, and a steady hand, you could do this yourself.
The Tools: http://www.6thgearadvertising.com/mi...l/DSCN1028.jpg You'll need a small soldering iron and some very small needle nose pliers. http://www.6thgearadvertising.com/mi...l/DSCN1034.jpg Use thin solder like on the left. Here is an Auto P28: http://www.6thgearadvertising.com/mi...l/DSCN1021.jpg you only need to be concerned with the area in the red circle, everything else stays the same. You can see the code on the top left... the second to last number is a 5. check this thread for a quick reference to tell if your ECU is auto or manual: http://civic-eg.com/viewtopic.php?p=10568 http://www.6thgearadvertising.com/mi...l/DSCN1025.jpg To convert the ECU to manual, you'll be removing the resistors from RP17 and RP18. Then Replacing the RP18 resistor with a jumper. Above, the Resistors have already been started on... http://www.6thgearadvertising.com/mi...l/DSCN1024.jpg Here's the back sude of the board. You can see the 2 empty spaces where I have already pulled the RP17 and RP18 resistors through. Notice the remaining resistors... The wire that goes through is bent down like a tab & soldered to the board. To remove the resistor, you first need to heat up that solder and bend the wire straight up so that you can pull it through the board. http://www.6thgearadvertising.com/mi...l/DSCN1026.jpg Now back to the top of the board, I have pulled one side of the RP17 resistor completely through. After you bend the tabs on the bottom, heat the terminal from the top and the resistor will pull right out when the solder becomes liquid. http://www.6thgearadvertising.com/mi...l/DSCN1027.jpg Here the resistor has been completely removed. Just repeat the process for the other resistor now. http://www.6thgearadvertising.com/mi...l/DSCN1029.jpg The resistor in RP18 needs to be replaced with a jumper. A jumper = a solid wire. To do this, I took one strand of wire from a copper wire. This wire was not the kind with the real fine strands like some expensive speaker wire, but just your average 14 ga power wire. http://www.6thgearadvertising.com/mi...l/DSCN1030.jpg In the pic above, You can see I cleaned out the top hole of RP18 using the vacuum. You'll be installing the jumper in RP18, so the holes need to be open. RP17 doesn't matter if the holes are clean or filled with the old solder. http://www.6thgearadvertising.com/mi...l/DSCN1032.jpg take your single strand of wire and bend it in a U shape, then put it through from the top side of the board. http://www.6thgearadvertising.com/mi...l/DSCN1033.jpg On the bottom of the board, bend the wire to make tabs. Mine are a little long... I trimmed them down to the same size as the others after the pics. http://www.6thgearadvertising.com/mi...l/DSCN1035.jpg Here I soldered the jumper from the top side of the board. The soldering iron wasn't very clean and the first solder I made on the top of RP18 is a little dirty. I used the vacuum to remove it and do it again. Clean your iron first! http://www.6thgearadvertising.com/mi...l/DSCN1036.jpg Here's another pic of the back of the board, before I finished trimming down those tabs. This whole operation takes less than 30 mins. Now you won't get a CEL 19 when using an auto P28 in a manual car! thanks to civic-eg for the diy |
wow thats perfect timing for me, thanks!
