DIY Oil Sandwich Plate Install
5 Attachment(s)
1. Why would you want to do this?
To be able to install an Oil temp and/or pressure sensor. To be able to install an oil feed line for a turbo system. 2. How long does this take? ~1 hour, taking your time. 3. Precautions? Nothing really. If you just drove the car recently, then the oil will be hot. Wait about 2 hours for the oil to cool completely. 4. What's needed? Oil Sandwich Plate Oil Sandwich Plate center bolt Replacement oil filter Replacement oil Any applicable oil gauges or oil lines 5. Tools needed: 17mm wrench to remove oil drain bolt. Oil filter wrench (not necessary, but helps if the oil filter is on too tight) Oil drain pan Socket wrench, or torque wrench Jack 2 jack stands Step 1 - Removing Oil filter Jack up vehicle. Always use jack stands. Crawl under vehicle and remove oil drain plug to allow oil to drain into pan. Re-install oil drain plug once all oil has been drained. Attachment 9126 Locate Oil filter on your vehicle and remove. Attachment 9127 Step 2 - Prepping Oil Sandwich Plate Install any and all sensor senders or oil lines onto the Oil sandwich plate prior to installing plate onto the engine. I have installed an Oil temp sensor here. Attachment 9128 Be sure to tighten all parts of the Sandwich Plate prior to installing. Choose the correct adaptor by threading the female end onto your engine. If two or more of the adaptors fit onto the engine, thread the adaptors into the oil filter to determine which adaptor is to be used. Step 3 - Installing Oil Sandwich Plate Slip Oil Sandwich Plate onto the engine. Be sure to have the rubber O-ring on the sandwich plate against the engine. Slide center bolt through the middle of the Oil Sandwich Plate and thread onto the engine. Be sure to move wiring or oil lines as needed. Attachment 9129 Torque center bolt to 30 ft lbs. If a torque wrench is not available, may sure the center bolt is nice and tight. Install replacement oil filter onto center bolt and tighten. Attachment 9130 Fill engine with replacement oil. Start vehicle and check for leaks. If leaks are present, remove oil sandwich plate and confirm that everything has been installed correctly. Step 4 - Maintaining your Oil Sandwich Plate With every oil change, be sure to re-torque the Oil Sandwich Plate center bolt as removing the oil filter may loosen it over time. Again, if no torque wrench is available, make sure the center bolt is tight. |
