basemap on s300
Old Oct 10, 2007 | 05:38 AM
93sir's Avatar
Default basemap on s300
I know i got a lot to learn and this might be a stupid question but do you need a basemap with hondata s300..?
Old Oct 12, 2007 | 03:26 AM
97civicruiser's Avatar
Default RE: basemap on s300
Yes you do need a base map and here are some hints to get you started!
If the motor is completely stock then use the map for that motor. These are the exception. (of course calibrate for different sized injectors)
ITR - use JDM P30 map scaled to 1.8L from 1.6L
GSR with Skunk 2 Intake Manifold - use JDM P30 map scaled to 1.8L from 1.6L
H22 - use P72 map scaled to 2.2L from 1.8L
H22 with European/JDM Intake Manifold - use JDM P30 map scaled to 2.2L from 1.6L
B20B - Use P74 or P75 map scaled to 2.0 from 1.8L
B20Vtec with B16A Cylinder Head - use JDM P30 map scaled to 2.0L from 1.6L
B20Vtec with GSR Cylinder Head and GSR Intake Manifold - use P72 map scaled to 2.0L from 1.8L
B20Vtec with GSR Cylinder Head and Skunk 2 Intake Manifold - use JDM P30 map scaled to 2.0L from 1.6L
hope this helped=-)
didder
Oct 20, 2008 03:45 PM
bcrichguitars
25
Oct 16, 2008 05:27 AM
didder
Feb 4, 2008 12:33 PM
FlipHKD720
Dec 11, 2006 11:29 AM
Skrapdoggydog
Aug 15, 2006 04:21 PM
